Welcome, Guest
  • Page:
  • 1
TOPIC: Barnett Clutch Plates - That old chestnut
Barnett Clutch Plates - That old chestnut 11 Jan 2019 07:06 #1
  • Benlypage
  • Benlypage's Avatar Topic Author
  • Novice
  • Novice
Hi Yamagurus
It's probably been asked a thousand times, but please bear with a newbie. I've had clutch slip on the '68 DT1 and decided after reading lots of posts to go for a Barnett clutch plate replacement kit. Anyway received the Kit and NOS stock springs but I have a few questions.
Firstly, the 6off rubber cushions(O rings) do we keep them in, as they appear to make the clutch plates a bit too thick?
Secondly, I don't seem to have much plate seperation, and can't seem to get a free clutch.
I don't want to put it all back together with a new gasket to have to take it apart again.
Thanks as always
Ray
Last Edit: by Benlypage.
Barnett Clutch Plates - That old chestnut 11 Jan 2019 07:40 #2
  • RTD2
  • RTD2's Avatar
  • Site Contributor
  • Site Contributor
I have Barnetts in three of my Yamahas including my 68 DT1. You don't use the O rings and you definitely have them installed wrong. Sorry, but you are going to have to go back in!
The following user(s) Liked this Post: Benlypage, asco
68 DT1, 70 DT1C MX, 71 CT1C, 71 RT1B, 71 DT1E MX, 73 AT3MX, 70 Husqvarna 250 Cross, 57 Matchless G80CS, 76 Honda Elsinore; 2015 Yamaha FZ-09
Barnett Clutch Plates - That old chestnut 11 Jan 2019 19:25 #3
  • Giancarlo124
  • Giancarlo124's Avatar
  • Site Contributor
  • Site Contributor
Did you get the clutch set with the additional friction plate? Did you remover the thick spacer from the back of the clutch basket?
The Oil burners: 1973 DT-250, 1966 YM-1 305, 1966 YSD3, YZ-105
Last Edit: by Giancarlo124.
Barnett Clutch Plates - That old chestnut 11 Jan 2019 20:25 #4
  • asco
  • asco's Avatar
  • Site Contributor
  • Site Contributor
Giancarlo124 wrote: Did you get the clutch set with the additional friction plate? Did you remover the thick spacer from the back of the clutch basket?
I think they are talking about a different bike. The bike that you’re talking about and you are correct is the 1974 DT 360
a
The following user(s) Liked this Post: Giancarlo124, Benlypage, Snglsmkr
YAMA-LAND RESTORATIONS
818-521-2109
MINIBIKESERVICE@AOL.COM CUSTOM MINIBIKE (RALPH) 2002 110cc XR PAX RACING 1971 125cc AT1-C (DOROTHEA) 1971 175cc CT1-C (BRANDY) 1970 250cc DT1-C (MONICA) 1973 100cc Hodaka Combat Rat (ABBY NORMAL) 1969 125cc AT1-M MX (DELILAH)
Barnett Clutch Plates - That old chestnut 12 Jan 2019 00:43 #5
  • Benlypage
  • Novice
  • Novice
Since the first reply from RTD2 about the rubber rings and I removed them it appears to be OK, I have left the thick plate in, and yes I received 7 steel and 6 friction plates.
The following user(s) Liked this Post: Pillsbury
Barnett Clutch Plates - That old chestnut 12 Jan 2019 09:47 #6
  • RTD2
  • RTD2's Avatar
  • Site Contributor
  • Site Contributor
Yes, if you had the orings installed, it would not have worked. Great to hear.
Mike
  • Page:
  • 1
