Welcome, Guest
TOPIC: Whoa what happened here
Whoa what happened here 05 Jan 2019 11:07 #1
  • Prinzy
  • Prinzy's Avatar Topic Author
  • Sportsman
  • Sportsman
Decided to throw s set of rings in my 71 dt today. So I slide the jug off and it comes off easier than expected like no resistance. I’m looking at the bore and heck there’s still hash marks from the last hone job and stock bore. Good there so I take the base gasket off and wtf? There’s two of them on there. That’s not right. So whatever they both come off easily. So I take the rings off the piston and hmmm where’s the inner rings. There’s just compression rings on it no inner rings. This can’t be right. No wonder I only had 105 psi compression
The following user(s) Liked this Post: FrankC, Pillsbury
Whoa what happened here 05 Jan 2019 12:58 #2
  • Wheel mad
  • Wheel mad's Avatar
  • Sportsman
  • Sportsman
Look on the bright side .. you now have a spare gasket !
I recently took the cylinder of my rt2 to find no gasket ,PO thought base gaskets came in a tube.
The following user(s) Liked this Post: FrankC, Snglsmkr
Last Edit: by Wheel mad.
Whoa what happened here 05 Jan 2019 13:02 #3
  • Prinzy
  • Sportsman
  • Sportsman
Lol glad I took this thing apart
Whoa what happened here 05 Jan 2019 14:44 #4
  • asco
  • asco's Avatar
  • Site Contributor
  • Site Contributor
Prinzy wrote: Lol glad I took this thing apart
Yep, 8 days ago you were about ready to sell the GYT head and call it good..
a
YAMA-LAND
818-521-2109
MINIBIKESERVICE@AOL.COM 1971 125cc AT1-C (DOROTHEA) 1971 175cc CT1-C (BRANDY) 1970 250cc DT1-C (MONICA) 1973 100cc Hodaka Combat Rat (ABBY NORMAL) 1975 DT400 (BONNIE BELL)
Whoa what happened here 05 Jan 2019 17:02 #5
  • Site Contributor
  • Site Contributor
A lot of people (including me) leave out the "ring expanders" (inner rings)... they can break. And if they do the result can be seizure. They seem to break more often with ported engines but I've seen them fail in a stock engine.
No harm at all in leaving them out and your compression will not change at all.
Whoa what happened here 06 Jan 2019 11:46 #6
  • Prinzy
  • Sportsman
  • Sportsman
Ok good to know should I just leave them out then?
Whoa what happened here 06 Jan 2019 11:48 #7
  • Prinzy
  • Sportsman
  • Sportsman
Gyt head isn’t going on. It needs a good home I don’t want to start jacking around with the timing and mess up a good bike. Should have done more research I guess live and learn
Whoa what happened here 06 Jan 2019 12:33 #8
  • Site Contributor
  • Site Contributor
I'm not smarter than the Yamaha engineers by any means! The expanders are only used on the second (lower) ring and I've seen claims that they keep the piston from rocking (not sure I buy that theory) to they help prevent the second ring from vibrating or fluttering in the groove (that theory sounds more likely).
I'm sure there are many opinions as to using them or not. I don't use them after finding them broken and getting advice not to from an experienced Yamaha engine builder much smarter than me. I'm not advocating that you don't use them. I'm only saying that "low compression" is not caused by leaving out the expander.
Maybe PM Enduronut and DEET and see what they recommend?
Since I'm on my soapbox I'll say that the presence of hone marks does not always mean the bore is good... having the piston and cylinder inspected by an expert like Enduronut is always prudent in my experience. ....at the very least have the cylinder honed to remove the glaze before installing new rings. (And of course the ports chamfers need to be checked/redone and the cylinder meticulously cleaned to remove all grit after honing.)
:Buds
Last Edit: by MarkT.
Whoa what happened here 06 Jan 2019 12:41 #9
  • Site Contributor
  • Site Contributor
Forgot to mention that not all pistons had the expanders... Any markings on the piston? That can help identify which rings you need.
Whoa what happened here 06 Jan 2019 14:29 #10
  • Prinzy
  • Sportsman
  • Sportsman
I didn’t really clean the carbon off of the piston to check for markings but I measured both bore and piston so I know it’s standard bore. Rings should be here tomorrow. I would have preferred to go first over n start fresh but with holidays and snowmobiling trips can’t spend too much. I’m gunna throw rings at it new wrist pin n bearing and see what happens. At least I’ll have peace of mind that base gasket head gasket and rings are new. I have another engine that’s stock bore I’ll probably just buy a 1st over piston n have it bored accordingly sometime n slap it on there
