Re:GFrench- 1971 DT1F MX Restoration
- pabdt
Replied by pabdt on topic Re:GFrench- 1971 DT1F MX Restoration
I've got an engine to clean tomorrow in same stage. Does Super Clean leave any film after drying?
________________________________________________
1969 Yamaha CT1 175
1974 Yamaha DT125A
1977 Yamaha DT250D
1969 Yamaha CT1 175
1974 Yamaha DT125A
1977 Yamaha DT250D
07 Nov 2025 20:14
#31
- GFrench
- Supporting Moderator
Replied by GFrench on topic GFrench- 1971 DT1F MX Restoration
pabdt- I have only used the Super Clean when I can rinse it really good with water so not sure about just spraying it on then trying to wipe if off...
For me WD-40 around controlled cleaning such as an engine etc... seems like the better way to go.
I also use a wood Skewers to get into all the nooks and crannies to loosen up the packed in gunk with the WD-40 then wipe wipe with Paper towels to get the mass off...
My goal for this bike is to not make it OVER Restored... everything is in pretty good / original shape and that is the way I want to present the finished bike.
1971 DT1F MX 250
1973 RT3 360 "Black Widow"
1973 RT3 360
1976 IT 400 / redesigned as a 75 MX400
1971 DT1F MX 250
1973 RT3 360
The following user(s) Liked this Post: MarkT, swm, Ht1kid
- GFrench
All the Gloss Black parts are now Cleaned- Scotch Brite prepped and final wipe done with Isopropyl Alcohol.
Will be time to lay down the new paint... excited to see how this Eastwood Paint works.
Also- got the new Parts Washer all set up and ready to go!
I mounted it on a furniture dolly- makes it easy to just roll it around where needed.
1971 DT1F MX 250
1973 RT3 360
1971 DT1F MX 250
1973 RT3 360
The following user(s) Liked this Post: Rick C., swm, Ht1kid, Sneezles61
- pabdt
Process is looking great!... the cleaner on wheels is awesome.
Sorry, my question was not clear. I have a problem w/Simple Green that after washing, rinsing, drying, a dry film frequently occurs on the part. I have a solution for that, Just searching around for new stuff to try and was wondering what Super Clean did after drying, but I guess I can just try it huh.
Thought I saw Super CLean on amazon...thinking I may give it a go.
1969 Yamaha CT1 175
1974 Yamaha DT125A
1977 Yamaha DT250D
1969 Yamaha CT1 175
1974 Yamaha DT125A
1977 Yamaha DT250D
10 Nov 2025 23:20
#34
Replied by MarkT on topic Re:GFrench- 1971 DT1F MX Restoration
Super Clean will discolor and corrode aluminum if you leave it on too long, but so will Simple Green. So don't drop a carb in straight Super Clean and let it soak overnight or anything.
The Castrol stuff works great and is basically a weaker liquid form of Easy Off oven and stove cleaner
The following user(s) Liked this Post: GFrench, Ht1kid
11 Nov 2025 08:02
#35
