Re:Just got a new project
Replied by MarkT on topic Re:Just got a new project
The starter/generator is not a permanent magnet AC type that could use that type of regulator.
Your DC starter motor-generator needs a regulator that senses the output voltage and then varies how much battery voltage is sent to the electromagnets in the generator. More voltage to electromagnets = stronger magnets = higher output.
Some Yamaha's like the RD350 had a similar-looking generator and similar in that it varies the output with electromagnets... the difference is that those are AC output that use diodes to convert the AC to DC... and they can't be used as a starter motor... in other words the RD350 has an alternator.
The ebay unit you pictured is for a "permanent magnet alternator" which has fixed magnets and the output is the output... no electromagnets and no variable output. That type of regulator either "bleeds off" the extra power made to keep the voltage in check or intermittently connects the output to keep the voltage in check... "bleed off" type is more common... extra power is turned into heat which is why they are finned like heat sinks.
12 May 2020 12:41
#61
- Godlygaz
- Topic Author
Replied by Godlygaz on topic Re:Just got a new project
So trying to understand what you are saying...So are you saying that this will not work as a regulator? And I need one that will be more like the traditional on/off/bypass type?
Sent from my POCOPHONE F1 using Tapatalk
14 May 2020 05:30
#62
You bought an AC regulator for a permanent magnet alternator. It will not work on your electromagnet DC motor-generator.
14 May 2020 06:27
#63
- HouseofEnduro
Replied by HouseofEnduro on topic Re:Just got a new project
MarkT your in depth knowledge of all aspects regarding these motorcycles is nothing short of amazing, I enjoy reading each and every one of your topic responses simply to see what new obscure tidbit of information I can learn. Thank you for taking the time to carefully answer so many diverse questions and help so many people with your seemingly infinite mechanical, electrical, and historical wisdom.
The following user(s) Liked this Post: MarkT, t-bone, 2fishkev, swm, yamahahaha, Schu, Lizeec
14 May 2020 07:42
#64
- Schu
Replied by Schu on topic Re:Just got a new project
Everybody, grab your mugs!
To MarkT
CT1B, CT1C, JT1, JT2, DT360A, GT80B, DT100B, DT125B,
DT175B, DT175C, DT250B, DT400B, Z50, SCR950
The following user(s) Liked this Post: 2fishkev, KennyV
14 May 2020 15:25
#65
- Godlygaz
- Topic Author
So I have a spark , compression is sitting around 110-120psi, and I can't get it to start ... Any ideas?
Edit - could be the carb but I do have a wet spark plug and the excess fuel is dripping out from the exhaust port
- Godlygaz
- Topic Author
ITS ALLLIVVVEEE!!!!!
Running a touch rough and I'm not even going to attempt to get the wheels in motion, but I finally have it running!!!!!
This is a big step !!
The following user(s) Liked this Post: t-bone, Gr8uncleal, Pete-RT1
04 Jun 2020 09:22
#67
Replied by Gr8uncleal on topic Re:Just got a new project
Great news! Anything specific that you think sorted it?
04 Jun 2020 09:50
#68
- Godlygaz
- Topic Author
I think the carb had alot of hidden reside from it being sat for a while, although I had cleaned it previously I must have missed a bit.
So I soaked the whole thing in a bit tub of oxalic acid that I made up for de rusting the fuel tank.
04 Jun 2020 12:29
#69
- Godlygaz
- Topic Author
Going on a previous post.
Now I know that the new magnet type voltage regulators are no good I'm looking back at the original one to get going.
I'm going to need to look into replacing the capacitor's on it however after a quick inspection the capacitor's look a bit unusual. Every capacitor I have ever seen has a negative and positive side ( 2 pins) but the ones on the VR has just a single pin.
Have I got this wrong or is it not a capacitor at all?
07 Jul 2020 05:00
#70
