My 3rd DT-1!
21 Jul 2019 21:33
BajaBronco
Novice
Novice
More
My 3rd DT-1! #11
Had some time today so filled my oil tank with yamalube and bled the system and popped off the cylinder feed to be sure. Checked oil level. Added gas, put on a unifilter for now, and she started 3rd kick. Ran and idled, I messed with idle and brought down to 1800 (high I know), Let it warm a bit and ran it up and down driveway. What a feeling!!
Left it for a bit and came back to air tires and take it around the block and now won’t start. Drained carb, checked spark, checked gas, checked carb bowl and jet, all about 3x each. No start.
Wondering what to do now. Sounded awesome and felt good when it ran. I’ll try to post video.
Andrew
71 DT-1E 11/70
71 DT-1E 12/70
21 Jul 2019 22:02
HouseofEnduro
Site Supporter
Site Supporter
More
My 3rd DT-1! #12
I hate it when that happens! I've experienced it too many times. First thought is that it is flooded - you said the engine had been warmed up, did you use the choke when you went to restart it? Sometimes that floods it. Pull the plug to inspect, if flooded it will be wet. Kick it through without the plug a few times, throttle wide open, check for spark, if all is good reinstall and try again. You can also simply wait overnight and it will quite possible correct itself.
The following user(s) Liked this Post BajaBronco
30 Jul 2019 21:37
BajaBronco
Novice
Novice
More
My 3rd DT-1! #13
Figured out what was up with mine today. I cleared out carb a bunch of times, checked spark once, tore carb apart, took fuel petcock apart....had no luck with any of those, but today had some time and checked spark again. Once in a while I'd get a spark when kicking it over. I thought maybe bad grounding of plug, but I made sure it was grounded now and it was sparking only some of the time. So I pulled the cover off the Magneto, pulled magneto (luckily still had my puller from years ago), and found it was all crusty inside. cam portion rusty, magnets rusty, etc. and wire from points worn from rubbing on magneto. Also - my lighting coil is gone...bye! Glad I didn't try the lights. Anyway, repaired wire, cleaned magneto, light grease on cam hub, and put back together. Points not opening - crust had worn down the follower on the point set. Faked point gap to be sure I had spark still. Put back together again and had good spark. Finalized assembly and it started right up! This time it re-starts, etc. Super happy now. I should find a lighting coil and also remake the wire to points that was worn thru the insulation. But for now it's not rubbing and runs well. Seems to like 2000 rpm idle setting to start, but then runs fine warm at 1400. Doesn't like to start at 1400. I turn it up a little to start cold. Will post some pics soon. Next step is tires, and maybe oil leaks and rear fender paint, front fender re-vamping. ( I always run a hi fender).
Andrew
71 DT-1E 11/70
71 DT-1E 12/70
30 Jul 2019 21:54
BajaBronco
Novice
Novice
More
My 3rd DT-1! #14
Here are some pics to go with it.
Andrew
71 DT-1E 11/70
71 DT-1E 12/70
31 Jul 2019 04:48
MarkT
Site Supporter
Site Supporter
More
My 3rd DT-1! #15
Great job!
31 Jul 2019 04:53
Nitto05
Open Class
Open Class
More
My 3rd DT-1! #16
Hey we bike buddy's but myne is red
With a strong will you can achieve anything
31 Jul 2019 16:08 31 Jul 2019 16:11 by BajaBronco.
BajaBronco
Novice
Novice
More
My 3rd DT-1! #17
Cool, my 2nd DT was a red 70. Had it the longest. Maybe 3 years. 1999-2001
I’ll go thru my photos and start a different thread of some of the bikes I had. 2 of the rts I want back so badly! Ugh
Andrew
71 DT-1E 11/70
71 DT-1E 12/70
The following user(s) Liked this Post KennyV
13 Sep 2019 13:00
BajaBronco
Novice
Novice
More
My 3rd DT-1! #18
I'm getting ready to ride my DT on some trails with a friend next week. Getting registered today and have title and PO's non op form with plate number. I decided since I had the original owners details to google and him, find a number and call him. He's 75 and bought it brand new. He said the license plate fell off in Barstow around 1973. He told me where to look for it! I think I'll pass at least right now. He did say he got 50.00 off the bike new because it had one small scratch and he bought it from Dick Allen Yamaha in Newhall, ca. It still says that on the buddy seat. He also mentioned he'd only had a Hodaka ace 100 before and the day after getting the bike he launched it over some railroad tracks and ruined the rear fender pretty badly. I had already replaced it - thats the first thing I did. Anyway, cool to hear some original owner stories!
Andrew
71 DT-1E 11/70
71 DT-1E 12/70
The following user(s) Liked this Post MarkT, KennyV
13 Sep 2019 14:23
MarkT
Site Supporter
Site Supporter
More
My 3rd DT-1! #19
Great story!
13 Sep 2019 17:58
Rick C.
Collector
Collector
More
My 3rd DT-1! #20
BajaBronco wrote: I'm getting ready to ride my DT on some trails with a friend next week. Getting registered today and have title and PO's non op form with plate number. I decided since I had the original owners details to google and him, find a number and call him. He's 75 and bought it brand new. He said the license plate fell off in Barstow around 1973. He told me where to look for it! I think I'll pass at least right now. He did say he got 50.00 off the bike new because it had one small scratch and he bought it from Dick Allen Yamaha in Newhall, ca. It still says that on the buddy seat. He also mentioned he'd only had a Hodaka ace 100 before and the day after getting the bike he launched it over some railroad tracks and ruined the rear fender pretty badly. I had already replaced it - thats the first thing I did. Anyway, cool to hear some original owner stories!
Sounds like you are close to Santa Clarita. Dick Allen's was the place to go.
Now there is PitPro. ( My local shop. )
