CT1 carb setter o-ring size
13 Jun 2019 00:03
gw1170
Sportsman
Sportsman
More
CT1 carb setter o-ring size #1
Hi, can anyone tell me the dimension's of the small o-ring that fits on the carb setter in the float bowl area ? I can get one but with post they want £20 !!!! (was hoping to buy some from ebay for a cheaper price if I have the size !) thanks
13 Jun 2019 01:27
Mothersbaugh
Collector
Collector
More
CT1 carb setter o-ring size #2
cheaper by the dozen?
13 Jun 2019 03:32 13 Jun 2019 03:46 by RT325.
RT325
Collector
Collector
More
CT1 carb setter o-ring size #3
www.partzilla.com/catalog/yamaha/motorcycle/1972/ct2/carburetor
Number 5. $2.82 Not sure on freight though.
www.2wheelpros.com/oem-parts/yamaha-o-ri...4147-00-00-part.html
Interesting what you find out as it says this part is used in 216 different assemblies
13 Jun 2019 06:09
MarkT
Site Supporter
Site Supporter
More
CT1 carb setter o-ring size #4
If you search the forum you'll find the answer... there's a common plumbing o-ring that comes in Nitrile and is reported to work well. I'll look later... have to rush off right now. Try "danco" as a search term.
13 Jun 2019 11:07
Rick C.
Collector
Collector
More
CT1 carb setter o-ring size #5
The following user(s) Liked this Post KJB
13 Jun 2019 18:43
MarkT
Site Supporter
Site Supporter
More
CT1 carb setter o-ring size #6
Rick's search link didn't work for me... only showed today's posts. I must have done something wrong?
Here's a search result to one of the posts I was thinking of in case someone else had the same problem... I'm not the greatest at navigating forums and links.
yamaha-enduros.com/index.php/forums/1968...tting?start=20#79727
13 Jun 2019 18:52
Rick C.
Collector
Collector
More
CT1 carb setter o-ring size #7
I messed up, Sorry guys ! :EEEK
13 Jun 2019 20:11
DEET
Moderator
Moderator
More
CT1 carb setter o-ring size #8
I have them.... they will fit in a letter.
The following user(s) Liked this Post MarkT
16 Jun 2019 01:28
gw1170
Sportsman
Sportsman
More
CT1 carb setter o-ring size #9
Thanks for the help guys, I now have a pack of ten on their way via ebay !
